Blog Layout
Gigabyte BRIX PC
Simon Brown • August 13, 2020
Teeny-Tiny PC from Gigabyte
I received an offer from https://mini-itx.com, and as a developer can never have enough computers I bought this and added 8 GB RAM. I put Windows 10 professional on.
The Spec
Gigabyte Brix GB-BLCE-4000C fully assembled PC. The Gigabyte Brix GB-BLCE-4000C features a dual core Celeron CPU, ram up to 8GB Ram. It is a total fanless PC.
Base specification (this is configurable using options)
  • Intel Celeron N4000 2.6GHz
  • 4GB Ram DDR4
  • 500Gb Hard Disk
  • Gigabit lan (Realtek RTL8111HS)
  • Includes Wireless- Intel® Dual Band Wireless-AC 3168 & Bluetooth
  • Intel UHD Graphics 600 onboard, dual display capable with HDMI and VGA outputs.
  • Front 1 x Power Button, 1 x USB3.0, 1 x USB3.0 type-C
  • 1 x Headphone Jack, 1 x Microphoce Jack
  • Rear 1 x HDMI(1.4b), 2 x USB 3.0, 1 x RJ45, 1 x VGA
  • Side 1 x Kensington lock slot
  • Dimension 56.22 mm x 103 mm x 116.52 mm (2.21″ x 4.06″ x 4.59″)
  • Vesa mountable bracket included Supports 75 x 75 and 100 x 100 mm
  • 1 year parts and labour warranty
System:
  • Don't forget - this is a two core N4000 Celeron chip!
Verdict:
  • Hardware build quality is excellent.
  • Looks very good.
  • I received a 240 GB SSD instead of 120 GB as Gigabyte had run out of 120 GB!
  • Plenty of CPU power considering only two cores.
  • Runs a NetSDR at 1 MHz bandwidth acceptably, also fine at 2 MHz bandwidth.
  • Graphics on a HD monitor is usable but not fantastic.
  • Would struggle to run another resource-intensive program such as WSJT.
  • Would be fine as a server for one or two SDRs.
Future Use
  • This will be used for running the g4eli.sdr-radio.com DX Cluster sometime in 2020.
By Simon Brown February 23, 2025
16 MHz Bandwidth!
By Simon Brown January 30, 2025
Microsoft admits bug that kills PC’s audio
By Simon Brown January 13, 2025
After talking on QO-100 with Mike, G0MJW i've ordered a LibreSDR from AliExpress where it's known as "SDR AD9363 AD9361 ZYNQ7020 ADI Pluto communication experiment platform".
Share by:
