Version 3.0.14 addresses some of the problems causing breaks in transmission, mainly to do with buffering of data before it is sent to the pluto. Below is a check list, I hope you fine it useful.
USB Power
To reduce any problems caused by a lack of USB power use an external power supply and connect to a well-powered USB socket, preferable a powered USB hub. Smaller PCs such as NUCs may not be able power external USB devices and perform high CPU processing at the same time. More USB information is here [link].
Bandwidth
When starting Pluto use a low bandwidth - if using Es'Hail 2 (QO-100) there is no reason to use 3MHz on the narrow band transponder. Lower bandwiths such as 750kHz and 1.5Mhz have a correspondingly lower USB throughput, this reduces problems caused by the USB interface on Pluto.
Buffers
The buffers are show in the window below. here you see the data size sent to the Pluto with each call to the Libiio API as well as the state of the unsent data in the buffer.
When a radio runs in full duplex the transmitter and receiver are running at the same time; full duplex is recommended.
Half Duplex
- The waterfall and spectrum are muted (no data) while transmitting.
- If using Es'Hail 2 (QO-100) the beacon lock may be lost.
Full Duplex
- The waterfall and spectrum run while transmitting.
- The receiver audio is active, use the Mute option below to mute the receiver audio while transmitting.
Mute RX
If running in full duplex you may wish to partially or fully mute the receiver while you are transmitting.
Select Receiver Mute from the Transmit Options.
