3.1 Release
Simon Brown • July 26, 2021
Release Date
Version 3.1 is the cumulation of 6 1/2 years of programming, SDR Console can now be considered a mature program. This kit will be released on August 2nd, 2021.
The main updates are much improved performance (reduced CPU and GPU load) and the addition of a voice keyer. For a full list of fixes and changes look at the release notes. Download this release here.
After the release some weeks will be spent updating the website.
Performance
As a result of a complaint that SDR Console was slowing down after many hours of use, I looked at the user interface (Direct2D) and noticed that every time a window (render target) is updated all the resources owned by the window are validated, even if it's not necessary.
As a result I've been working on reducing the number of Direct2D resources created in each window which has had a very big effect on CPU when refreshing / updating a window. This is very important in the Spectrum and Waterfall windows which are regularly refreshed.
As a result this kit runs very well on a 32-bit W7 laptop which uses a Core2DUO 2GHz T5870 CPU from 2008. In fact, it runs so well that I've completely removed the automatic low power settings, these are now an option in the Ribbon bar, Tools, Settings panel.
The screenshot below shows an Airspy HF+ running on an i5-7260U laptop (2 cores, 4 threads), CPU load is an amazing 0.6%.
Conclusion
If the program uses any fewer resources it'll start running backward (joke).
Voice Keyer
Finally added a voice keyer, located in the Transmit panel.
Click the ••• button to configure the voice keyer. The configuration options support recording, selection of recordings and other options.
Format
Recordings are saved as WAV files, the default format is 48kHz single channel (mono) 16-bit samples. These files can be edited with most popular audio editing software, just make sure the sample rate is 48kHz and the sample size 16 bits (signed short integers).
Record
Here you create a recording. The input is the current microphone selection in the transmit panel. Save the recording as a 48kHz, mono wave (WAV) file.
Select
Select the WAV file(s) assigned to the [1], [2], [3] buttons in the voice keyer window.
Options
roger beep recording followed by a silence tail.
  • Slide title
    Select
    Button
  • Slide title
    Record
    Button
  • Slide title
    Options
    Button
By Simon Brown December 27, 2025
Follow These Steps If you're unsure how you add a radio definition to SDR Console, here are the steps you must follow. Start SDR Console (quite obvious really). From the Home tab on the ribbon bar, in the Radio panel click Select Radio , the Select Radio window is displayed. At the bottom right of the Select Radio window, click Definitions... , the Radio Definitions window is displayed. At the top left of the Radio Definitions window click Search , a list of all supported radios is displayed. Select the radio you want to add, for example Airspy, SDRplay. In this example the RX-888 will be added. When you select an option from the list in step 4, either a radio is found or not. If the radio is found, a window is displayed with the option of adding the new definition. If the radio is not found, an error window is displayed. If this is a radio connected by USB, make sure the USB port can supply enough power. After adding the definition, click Save in the Radio Definitions window. You can now select your radio in the Select Radio window. That's all folks! SDRplay If you are using a SDRplay you select SDRplay > V3 in step 5 above. Make sure you have also installed either SDRconnect , SDRuno or the latest API (currently 3.15 at the time of writing).
By Simon Brown December 19, 2025
Version 1.5.4 This release fixes a bug, improves the user interface. Download link is at the bottom of this page.
By Simon Brown November 1, 2025
November 1st, 2025 Analyser Analyser tag window change, as suggested by Jim. Analyser tags now saved and restored correctly. Analyser font size now supports small, medium and large. Analyser loads saved projects faster. Saving project now much faster and uses less memory. More display lines available if you have enough RAM: Less than 16GB then 50,000 lines. 16GB to 32GB then 100,000 lines. 32GB or more then 250,000 lines. Fixed minor font issue with definition window. Fixed issue scrolling when more than 32768 lines in display. Data File Playback Selecting a playback folder now creates the list of files much faster. Emulation Added a diagnostic check for the use of emulators. This code only works on W10 and above, so I dynamically load IsWow64Process2 from kernel32 which avoids issues on older versions of Windows. In the logfile you see something like this: 05:23:48.185: Vendor ....: GenuineIntel 05:23:48.185: Brand .....: Intel(R) Core(TM) Ultra 7 265K 05:23:48.185: - 05:23:48.185: x86 Emulation: 05:23:48.185: Process .......: 0x0000, "Not emulated" 05:23:48.185: Architecture ..: 0x8664, "AMD64" 05:23:48.185: - Favourites Updated the default 60m bandwidth. Changed Broadcast :: VHF CCIR title to Band II. Groups now have user-selectable files. Default definitions renames to main. Changed the ribbon bar, Selection entry to Options (see image below). The dropdown options have been replaced with a single window, allowing more room for text. Locked Receivers If the program is stopped or a favourite created when a receiver is locked, this caused problems with the receiver being locked but no indication. With this kit receiver lock state is not applied in a favourite definition. Logfile Automatically save the logfile when closing, really added so I can check program responding correctly to Shutdown and Restart. Old logfiles are purged after the program has been running for one minute. Logging Added logbook FA option as below, FA is the command to read/write RX1. Narrow FM Added 150Hz CTCSS squelch tone. De-emphasis is now optional, selected from: Ribbon bar, Receive, Mode..., Narrow FM. Persistent Display Got a crash inside the persistent display logic, my sanity checks weren't good enough so have improved this. Remote Server After connecting to a remote server, the input fields can now be edited to change connection parameters. Ribbon Bar View panel tidied up. Signal Meter (SMeter) Added more presets for the Signal meter, Ribbon bar, View, Spectrum, Signal Meter. Spectran ECO Changed SPECTRAN path order to pick up DLLs from the SDK folder rather than the main folder. Status Bar GPU, Audio entries on status bar now optional, selected from Program Options, Performance, CPU Memory. System Shutdown / Restart If SDR Console is running when the system shuts down or restarts then SDR Console closes gracefully. What happens - five seconds after SDR Console receives the SHUTDOWN message a timer calls the OnClose() processing, so you have five seconds to about the shutdown / restart. Text Size Fonts now scale correctly when a non-default Accessibility > Text Size is selected (see image).
By Simon Brown October 29, 2025
SDR Television v1.0.1 October 29th, 2025: Fixed a fatal bug in the receive AGC if the output soundcard sample rate is 96kHz or 192kHz. Downloads are at the bottom of this page.
By Simon Brown October 25, 2025
Previous: Version 1.5.2 This release fixes a bug, improves the user interface and adds a new calendar. Download link is at the bottom of this page.
By Simon Brown October 12, 2025
And the award goes to...
By Simon Brown October 9, 2025
Version 1.5.1 This is a mainly cosmetic update to version 1.5, nevertheless well worth installing.
By Simon Brown September 13, 2025
SDR Television This release is actually beta 6 with a few small updates, so I've left the beta 6 text here. I hope to start working on this in November 2025, adding the Gardner timing error detection which should improve the decoding with low SNR. Downloads are at the bottom of this page.
By Simon Brown September 9, 2025
Hello Again I'm now back to 90% SDR Console support, so here's the first beta for at least eight months. Scroll to the bottom for a link to the beta kit. The source is fully archived, so crash dumps can be analysed.
